MTA Fast hitch
Tom Graham
09-08-2005 09:46:55
Will a fast hitch from a 460 fit an MTA, or do I need one from a 560?
McDiesel
09-08-2005 23:12:57
 Re: MTA Fast hitch in reply to Tom Graham, 09-08-2005 09:46:55
Tom, Hugh is 100% right, Not only are the bolt holes not there but the deck is narower too.
Too Far Gone
09-08-2005 17:20:13
If you want an accurate hitch for the Mta,One from a 400 with the early style fast hitch(with the belly cylinder) would be the one.
Harold H
09-08-2005 10:30:41
SMTA same size housing as 560. 460 will not fit. 400, 450, or 560 will fit.
Harold H
KIP in MX
09-08-2005 11:40:23
 Re: MTA Fast hitch in reply to Harold H, 09-08-2005 10:30:41
Harold,
All of the 400 hitches Iīve seen were different than the 450. I didnīt think a 400 hitch would bolt on to a SMTA.
Harold H
09-08-2005 13:53:22
 Re: MTA Fast hitch in reply to KIP in MX, 09-08-2005 11:40:23
We have put 400 hitches on 450's, many years ago, so I would think they would work on a SMTA. I believe my memory is correct on this but I can't guarantee it.
Harold H
Hugh MacKay
09-08-2005 15:06:40
 Re: MTA Fast hitch in reply to Harold H, 09-08-2005 13:53:22
Harold: You are right and he is right. 400 hitch will fit 450, but not SMTA. SMTA is not drilled for the lift arm pivot.
Tom Graham
09-08-2005 16:02:00
 Re: MTA Fast hitch in reply to Hugh MacKay, 09-08-2005 15:06:40
460-560 style doesn't have left arm pivot?
Hugh MacKay
09-08-2005 19:22:28
 Re: MTA Fast hitch in reply to Tom Graham, 09-08-2005 16:02:00
Tom: Some may have been discussing 460-560, I was not. All I am saying is SMTA was not drilled for it thus any fast hitch mounted on an SMTA must come from a 450 or 560. The 400 type hitch will not bolt up, and that pivot is the problem. Shame in a way as the 400 hitch was by far the best hitch.
