d236 vs d282
Charles Poosch
08-24-2005 07:13:02
Are the engine blocks for the d236 from a 460 and the d282 from a 706 the same? I know they had the same bore with a bigger stroke for the 706. What, if anything, changed? Or are they totally different?
Thanks,
CP
migraine
08-24-2005 08:24:55
 Re: d236 vs d282 in reply to Charles Poosch, 08-24-2005 07:13:02
The 236, 282, and 301 are all the same block. The 282 cu in was achieved by using a crank with a longer stroke. This was used in the 560, 706, and the 656. The 301 had a bigger bore and was used in some of the combine models as well. Prety good old tough motors but start hard. Need a good battery and the glow plugs to all work properly. Migraine
captiank
08-25-2005 17:44:18
 Re: d236 vs d282 in reply to migraine, 08-24-2005 08:24:55
As stated, the 282 has a reputation for being an real bear to get started, however...there are exceptions to this.
I have one in a 560 that is a real good starter. I have already started it to -12 F when the engine heater failed. It was a bit grouchy, but did go. In the winter I run straight 10-10W oil, and at least 75% #1 fuel. The valves and seats are all very close to original factory spec, and the pump and injectors are all good. Good batteries are a must and also good glow plugs.
My 2 cents.
Charles Poosch
08-24-2005 07:18:57
Forgot about the d309, too. Was the d309 the "German Diesel"?
CP
Txsprigger
08-24-2005 11:02:52
 Re: d236 vs d282 in reply to Charles Poosch, 08-24-2005 07:18:57
The German diesel was a 310.
