Touch Control help
Roch Coureges
08-06-2005 05:24:44
Hi I have a 1953 Super C with the hydraulic Touch Controls. I was able to get a rebild kit for the pump and hydraulic unit but i need to fins a shop in So. Cal. the will rebild it for me. anyone know where i could take it to get rebilt??
any help would be great
Thanks roch
CNKS
08-06-2005 08:37:04
 Re: Touch Control help in reply to Roch Coureges, 08-06-2005 05:24:44
Listen to Scotty. The job is time consuming, but simple.
El Toro
08-06-2005 06:15:23
Look in your yellow pages under hydraulics and find a store that sells Aeroquip, Alemite or Weatherhead hose and ask them if they can recommend a company in your area to rebuild your pump. You may better off to contact SteelWheelRanch to see if they have a rebuilt pump. Their number is 785-548-7437. I know they have rebuilt Cessna pumps for the 460 tractor. Hal
scotty
08-06-2005 06:09:05
Roch, With just a few tools you can rebuild it yourself. Start by getting the manual from Binder Books for $7.95. When disassembling, I used clear plastic bags and numbered them to correspond to each bore in the unit, paying attention to the sequence of parts. After taking it all apart, I cleaned the entire unit in a solvent tank and blew all the passageways out with compressor. When reasembling use some oil in the bores for the o-rings, and make sure everything is good and clean.
You can do it!
scotty
