rear main oil seal in 460
J Muehring
07-04-2005 18:08:53
I split Farmall 460 to replace TA clutch disk and to look at engine clutch. There is oil all over in side of housing,I assume from engine oil. How much trouble to replace rear seal. Will I have to drop crank to get at it and can that flywheel be man handeld with breaking back ? Thanks for all inputs.
ejr-IA.
07-04-2005 19:33:04
 Re: rear main oil seal in 460 in reply to J Muehring, 07-04-2005 18:08:53
Take the flywheel off and pull the old seal out then replace with new one if the crank is grooved a little get a speedy seal or put the new one in a differant location on the crank.
