T20 manifold ?
Nebraska Cowman
06-17-2005 18:27:36
I got a call from a shop in Clymer New York. Jim is working on a T20 for a customer and needs a manifold. Does anyone know where to find one or will an F20 manifold fit?
Canetractor
06-18-2005 19:57:18
 Re: T20 manifold ? in reply to Nebraska Cowman, 06-17-2005 18:27:36
The difference in F-20 and T-20 original all fuel manifolds is the controll linkage for heatriser. The T-20 uses a stud a few inches up from carburetor for a lever to change direction of control to up motion (bellcrank). Why is this needed ? Because the operators manifold heat lever is positioned much lower on crawler. Notice on F-20 all fuel manifold a boss or mounting pad down near carburetor but not drilled and tapped (about the size of a nickle). The same basic manifold is used on both.
P Backus
06-17-2005 20:00:26
Hi cowman. I'm not sure what's different about them, but I understand that the T20 manifold is different than the F-20 manifold. I ran into that when i was looking for mine. I think that perhaps the F-20 manifold will fit, but there are differences. I realize that I'm not helping you much here.....
Paul
