SMT
Wratchet
04-11-2005 16:04:41
Farmall SMT
If I have an engine with a date stamp on the right side pad with a date of 1-12-58
Will that be a replacement motor? Else, why would the date be Jan 1958?
RustyFarmall
04-12-2005 05:04:14
 Re: SMT in reply to Wratchet, 04-11-2005 16:04:41
A friend of mine ran across this same thing awhile back, but in this case the date on the engine was an actual casting code that put the build date of the engine way beyond what would have been considered correct for that particular tractor. We could only assume that the block was a replacement.
CNKS
04-11-2005 17:51:58
I assume you mean a SMTA, built only in 1954. I'm not familiar with the numbering of replacement engines. There should be a casting number with raised letters of 1*12*D somewhere on your block (D is the notation for 1958) this could also be a different (earlier number) if the serial pad was stamped 1-12-58, if that is what you mean. It sounds like a replacement to me.
