died h still no spark
baler46
04-07-2005 16:27:19
Hi just wondering if there is any way to check the coil to see if it any good.And the condonser . thank you bruce
El Toro
04-08-2005 07:15:00
 Re: died h still no spark in reply to baler46, 04-07-2005 16:27:19
Hi Bruce, That was Wayne Swenson's posting for checking that ignition system. Hal
El Toro
04-08-2005 07:11:20
Hi Bruce, You need to check for battery voltage
as Michael recommended on your former post. Check for voltage at the ignition switch some of those H's have fuses in the light switch. Look at Dave's posting today as he has Bob Melville's
wiring diagrams posted. You need to make sure you have 6 volts at the coil with the switch on.
Hal
P Backus
04-07-2005 21:25:27
Do you have any other equipment that you know runs that you can exchange the coil and/or condenser with?
I'm pretty sure that there should be continuity between the two little terminals on the coil, however even if there is it doesn't mean the coil is good. An old time garage or auto electrical shop should have a machine to test coil and condenser.
Paul
El Toro
04-07-2005 17:27:27
I would replace the condenser, then see if the tractor will start. Have you checked the rotor
for any residue? Clean the metal on the rotor that contacts the cap. Check for voltage at the coil with switch on if this is battery ignition.
Your switch could be the defective. Check for voltage at the switch then the coil. Hal
kfox
04-07-2005 22:51:58
 Re: died h still no spark in reply to El Toro, 04-07-2005 17:27:27
The only time my old H wouldnt start, all it needed was a point file run through the points very lightly, one time. Wouldn't fire a lick until then. ken
El Toro
04-08-2005 02:53:38
 Re: died h still no spark in reply to kfox, 04-07-2005 22:51:58
That was the problem with almost any engine that had points and a condenser that wouldn't start.
Even some with brand new points. I've even istalled new points and the engine ran worse and these were made by Standard which are very good points. They gave me a new set and that set was ok. I think they even made ignition parts for mags too. Hal
El Toro
04-08-2005 06:53:15
 Re: died h still no spark in reply to El Toro, 04-08-2005 02:53:38
Hi Dave, If that fuse feeds voltage to the ignition it could be the problem. Thanks, Hal
Dave
04-08-2005 06:31:41
I'm not sure,if the little dash fuse will kill run mode,seems I remember my H was wired that way.anyhoo,heres a link to Mr.Bob M's wiring diagrams,which is posted all thru the archives here.Take a look and good luck,the diagrams helped me over and over.
Geterdone454
04-09-2005 19:55:11
 Re: died h still no spark in reply to Dave, 04-08-2005 06:31:41
I had that problem with my 1945 H.When I changed the points ,I didnt get the wire just right that connects to the points and it was grounding out on the inside of the magneter.I check my magneters by taking them off and putting them in a vise ,then I take a drill with a wire brush on it,set it to run counter clockwise ,put it to the back side of the magneter and spin it while holding the coil wire about a quarter inch off the side of the magneter case.You should get a blue spark if its good.Be careful not to hold the end of the wire in your hand.Good luck
