Super M Clutch Removal
colekicker
04-04-2005 22:28:57
Ok, so I thought that you could remove the clutch from the belly of the tractor without splitting it. Is this just a myth or is it really true. If it is true, what must be done? It looks like it might be possible, but someone needs to tell me what pieces of the puzzle have to be removed here. I am getting a little confused and frustrated. Dad is starting to pull his hair out.
Andy Martin
04-05-2005 05:37:24
 Re: Super M Clutch Removal in reply to colekicker, 04-04-2005 22:28:57
The clutch disc will come out but not the pressure plate on the SM but not on the SMTA.
Clean the inside of the cavity and remove everything you can. There is just enough wiggle room to get the clutch disc out. Make sure you have the pressure plate compressed by putting the three mounting bolts in the holes to compress the pressure plate.
If you need the pressure plate out you'll need to split the tractor.
Dennis Gauge
04-05-2005 08:23:16
 Re: Super M Clutch Removal in reply to Andy Martin, 04-05-2005 05:37:24
I know I've seen it done, and it's not the easiest thing. I don't understand how, though. Doesn't the transmission input shaft ride in a pilot bearing in the flywheel?
Andy Martin
04-05-2005 11:21:30
 Re: Super M Clutch Removal in reply to Dennis Gauge, 04-05-2005 08:23:16
There is a spacer behind the transmission input shaft which can be removed to allow the input shaft to be moved to the rear.
len 650
04-05-2005 04:26:56
smta 400 450 all need to be split
MagMan
04-05-2005 03:24:13
As far as I know the early straight M could be changed that way along with the H but I think the SM has a clutch thats to big and you have to split it.I beleve the early Ms were 11" and the SM is 12" So start splitting her.
Van in AR
04-05-2005 01:38:26
Not sure about the Super M, but you can change the clutch in a H without spitting it, however you must spit a Super H because of the bigger clutch.
Van
