super m starter switch location??
drgw3101
03-27-2005 16:22:20
hello, my super m was missing a starter, i bought one and the switch mounts to the front of the nose cone, is this correct or should the switch bolr to the back end of the starter? it is a 3 bolt style..live hyd, and a switch mounted to the starter. thanks...
DWV
03-27-2005 18:12:17
 Re: super m starter switch location?? in reply to drgw3101, 03-27-2005 16:22:20
Correct starter should have a switch with lever
mounted on it with 2 screws, and a rod running
back to bracket on left side of hydraulic reservor
to engage switch.
JOSSETTE
03-27-2005 17:33:30
most of the new ones are that way. the wires from the switch and to the coil will be turned around is all
