OT 7.3 international
sparke806@earthlink.net
03-21-2005 20:20:28
Looking at a 1990 Ford with 7.3 diesel,was running good when it ran out of fuel owner has not been able to start it since. He bleed lines and thinks it's getting fuel. He has it priced cheap as is ,any ideal what could be wrong.
thanks
Bob
03-21-2005 20:24:48
 Re: OT 7.3 international in reply to sparke806@earthlink.net, 03-21-2005 20:20:28
"Thinks it's getting fuel?"
Loosen at least half the lines at the injectors and crank it over to see if it's REALLY getting fuel. (As you probably know, keep fingers and other skin away.)
Once you have fuel, check the glow plugs. May be a bad relay, or all 8 may be burned out from battery boosting/excessive cranking while trying to get fuel system bled after running out of fuel.
ChadS
03-22-2005 04:57:28
 Re: OT 7.3 international in reply to Bob, 03-21-2005 20:24:48
Is this the same BOB who helped me with my 93 Ford F-350 last fall? If so, just wanted to tell ya,, its running real good! Fianlly got the leak found, starts right up, and the advance is set to where it sounds real sweet. like a sewing machine. THANKS FOR YOUR HELP back then! ChadS
