old farmall
eg
03-16-2005 15:53:44
bought this old tractor to fix up but have
no idea what model it is . all i know is red
seat offset, 4cylinder ohv,4speed trans and
belly mower-woods.there is a plate rivited to
left side of bell housing but cant make out
anything on it.any help is grately appreciated!!!
Hugh MacKay
03-17-2005 15:04:39
 Re: old farmall in reply to eg, 03-16-2005 15:53:44
eg: Go with Jim Becker's idea 100, 130 or 140. Could possibly be a Super A1. Check that one out as there were only 1,957 of those ever built. Tractor has hydrauilc touch control under fuel tank. Just nice room to slide a 2x4 throught between the two.
Gordo
03-17-2005 06:22:47
Jeff, Can you reduce the size photos on your digicam? I only get about 1/5 of the picture, have to scroll arounfd forever, and it's slow to load. I liike the background for the tractor!
GordoSD
Jim Becker
03-16-2005 18:14:33
Serial plate on the bell housing means it is probably a 100, 130 or 140.
Paul in Mich again
03-16-2005 17:41:46
eg, on the left side of this site, you will see a menu under Galleries. Go there, and click on Tractor Photos. Once you get there, type in any one of the Farmall models you have been given in the below posts, in the "search for" box. You may see which model most closely resembles what you have. For example: (Farmall A), then the other models until you find what you are looking for.
Paul in Mich
03-16-2005 17:32:18
It could also be a Cub.
Bigdog
03-16-2005 17:33:47
 Re: old farmall in reply to Paul in Mich, 03-16-2005 17:32:18
Cub is 3 spd with flathead engine.
Paul in Mich
03-16-2005 17:44:37
 Re: old farmall in reply to Bigdog, 03-16-2005 17:33:47
You"re right, I wasn"t paying close enough attention. I"m certain though that its not a SBNTADV.
Jeff In Ontario
03-16-2005 16:32:21
third party image
Eg:
Does it look like this? This is a Farmall A.
Most likely a Farmall A or Super A. Look for these pictures in the tractor photos here also& see if you recognise it. Jeff
RAW in IA
03-16-2005 16:27:43
If it has a wide front end it wshould be an A, Super A, or later 100,130.140. If narrow fromt end should be a B.
