'super c ' voltage
skippy
02-24-2005 17:06:33
I have a 1952 super C. I cant read on any electrical part what voltage it is. Checked the coil and I cannot find the info anywhere. Do I have a 6-volt or 12 volt system. Thanks
JOSSETTE
02-25-2005 19:10:46
 Re: 'super c ' voltage in reply to skippy, 02-24-2005 17:06:33
if you need an easy to follow wiring diagram let know ?????
El Toro
02-25-2005 05:58:39
The firing order is 1-3-4-2 and No1 plug is near the radiator. The rotor turns CW so once you have rotor pointing to No1, the next plug wire should go to No3, then 4 and 2.
Does the tractor have battery in it now? If it does and it has 3 battery caps it's a 6 volt and if it has 6 caps it's 12 volt. Do you see a number on the generator? If it does, post it so we can check it out. Hal
El Toro
02-24-2005 17:20:05
How many cells are in the battery? If 3 it's a 6 volt system and if you have 6 cells it's 12 volt.
The Super C's were all 6 volt when new, some may have been converted to 12 volts. 12 volt batteries are easier to find too. Put a volt meter across the battery terminals to measure the voltage. Run engine at 1/2 throttle to 3/4. Hal
skippy
02-24-2005 17:36:53
 Re: 'super c ' voltage in reply to El Toro, 02-24-2005 17:20:05
The tractor isnt running (yet). The battery that is in it is a 12 volt battery but Iam not sure that it is the correct one. I just inherited this tractor and Iam trying to get it running. I dont know much about it. I have just put in new wires, plugs and condenser. I also need a fireing order diagram because Iam not sure that the plugs are going to the right distributor wires.
El Toro
02-25-2005 06:07:14
 Re: 'super c ' voltage in reply to skippy, 02-24-2005 17:36:53
I see it does have a 12 volt battery, post the model number off the generator or alternator.
Look for a resistor in the ignition circuit. This is used to drop the 12 volts to 6 for the ignition. If it has lights look at the bulbs to see what the voltage is. Hal
Curt (806 guy)
02-24-2005 18:17:28
If it has a 12 volt battery then it probably has been converted to 12 volts already. Does it have an alternator on it? If it does, then its 12 volts for sure. I cannot remember the firing order on that 4 cylinder engine for the life of me, I remember 6 cylinder engines but not 4. The firing order is stamped on one side of the engine somewhere. #1 cylinder is the front of the engine. The dist. cap has #1 stamped on it by the # 1 tower, it may have the rest of the cylinders stamped on it too. Someone can correct me if Im wrong, but I think the distributor rotates counterclockwise, so you put the wires on the cap in the firing order going counterclockwise around the towers on the cap.
JBlavl
02-25-2005 06:30:33
 Re: 'super c ' voltage in reply to Curt (806 guy), 02-24-2005 18:17:28
I thought the #1 cyl was closest to driver?? The firing order should be 1-3-4-2 but double check that on the casting on the block. And depending on what way you look at the distributor depends on what way it rotates. But I believe looking at the rotor cap it spins clockwise because it is the opposite way the crank spins. Someone correct me if I am grossely wrong. I am doing this from memory.
Ernie Bob
02-24-2005 22:18:38
Curt,
I would have to disagree with you on the statement that if it has an alternator on it then it's a 12 volt. I had a 6 volt Super C and it had an alternator on it and I just purchased a 6 volt alternator and put oit on my 200 Farmall. I believe the alternator that I put on last month had 6V stamped on it. Otherwise I would look to see if the generator or regulator has 6V on it. If it was a full 12 volt conversion then it should have a balast resistor in line between the coil and the distributor and lights should have been converted over to 6 volt.
Good Luck!
Ernie Bob
Curt (806 guy)
02-25-2005 10:37:27
 Re: 'super c ' voltage in reply to Ernie Bob, 02-24-2005 22:18:38
I have never seen a 6 volt alternator before, not saying that there isnt any, I just never knew they existed. But yes, the best way to know is to see what voltage is stamped on the alternator or generator.
Ernie Bob
02-25-2005 20:25:28
 Re: 'super c ' voltage in reply to Curt (806 guy), 02-25-2005 10:37:27
My wife bought me the 6V alternator as part of my christmas presents. She got it from JC Whitney for $79.00. She also got me a 12V for my 400 for $89.00. They both have been working great.
Ernie Bob
