How To
PAULIH300
02-17-2005 16:08:25
Removing the lid on a 300U's Hydraulic Reservoir,do you have to remove the Hydra Touch control valves?
I'm planning ahead for when(ever) I can get around to that..
big fred
02-18-2005 10:48:08
 Re: How To in reply to PAULIH300, 02-17-2005 16:08:25
I did, because the hoses were stubborn and wouldn't budge, besides, I wanted to get a coat of paint on the reservoir. Just remove the bolts, I think there are 4 bolts on each set of valves (I had three control valves and the pressure relief/regulator valve). Those bolts thread into the reservoir. There are O-rings that seal the ports, you will probably need new ones when you put it back together. Standard BUna-N O-rings will work just fine. When I did mine I just let the valves hang on the hoses when I unbolted them, lifted the reservoir cover up with a cherry picker engine hoist.
mark k
02-17-2005 21:05:26
I removed mine, hooked a hoist to the rafters and lifted straight up. Good luck. Mark
iester
02-17-2005 17:25:51
i left mine on,unhooked hyd hoses.the lid is heavy i used a comealong,raise straight up not to damage screen
Nebraska Cowman
02-17-2005 16:27:52
It might be easier to disconnect the valves than to fight with the lines.
