460 Heat Riser Question
Steve200460
02-02-2005 17:22:40
I read some past posts about 460's having a spring activated damper in the manifold to help with starting and running when it's cold out. My 460 won't start below 20 degrees but always starts above 35. Does anyone have a picture of what the damper looks like? Is the spring inside and outside? All I see poking out of my manifold is a shaft with a slot cut in it.
ejr-IA.
02-02-2005 17:31:03
 Re: 460 Heat Riser Question in reply to Steve200460, 02-02-2005 17:22:40
Your spring is missing most of these shafts are rusted up.
catmandoo
02-02-2005 19:34:58
 Re: 460 Heat Riser Question in reply to ejr-IA., 02-02-2005 17:31:03
there should also be another little shaft sticking out right next to it.this is what the spring hooks on
