Firing Order
Dm
01-22-2005 16:27:36
Any one know what the firing order should be for a 6-volt system ! Put new wires on from tractor supply (i dont recomend them)I thought that the firing order would be on the block but now i cant locate it! Also dose the rotor buttonturn clockwise or to the right if the button is at the top?
F-Dean
01-22-2005 19:51:19
 Re: Firing Order in reply to Dm, 01-22-2005 16:27:36
Double check the direction of rotation of the distributor. A W-30 will run with the wires in the oposite direction. Others may also.
CNKS
01-22-2005 17:28:45
All IH 4 cylinder engines have the firing order 1342, 6 or 12 volt does not matter, I have never seen one that did not have large raised numbers below the spark plugs. Dist cap terminals are arranged like this:
2 1
4 3 #1 plug wire to #1 on the cap, #3 plug wire to #3 on cap, etc.
MagMan
01-22-2005 16:33:18
1342 at cap Yes gas motor turns clock wise and #1 on the cap should be at about 1:00 The plugs go in order from front of motor to back 1234. I beleve I got this right some one will correct if not. I have a different way of doing it but it would only confuse you. JON
Jimmy King
01-23-2005 05:49:59
 Re: Firing Order in reply to MagMan, 01-22-2005 16:33:18
Except a gas start diesel distributer turns counter clock wise.
