300 u ipto
randy
01-10-2005 06:00:37
again.. cant stop my pto from turning..posted a message a couple weeks back. bought a manual followed the instructions on band adjustment ..still it turns ..if i loosen the bands i can roll the pto by hand but hear a clunk about mid point in the tractor . even tried to adjust them with the tracor running that seemed to change the engine rpm ..is there a cluth that could be froze up or bearing ..any suggestion would be helpful thanks
Aces
01-10-2005 15:17:48
 Re: 300 u ipto in reply to randy, 01-10-2005 06:00:37
Randy there are to bands in there one for drive and one for brake they are the same part number. The idea was after the drive band had been used to where it didnot hold like it should you switch the drive with the brake. But after this long who knows how many the tractor has had or the condision of them. But I agree with Van replace the bands.
Van in AR
01-10-2005 09:48:37
The band is shot, replace it and re adjust and you shoud be fine.
Van
B Watson
01-10-2005 06:43:41
I have a similar problem with the PTO on my 300, I have figured out that it is not the adjustment but seems to be the detent positions on the lever.
If I hold the lever down slightly the PTO does stop, how to fix it I haven't quite figured that part out yet.
Please post if you find the solution.
Thanks
randy
01-10-2005 06:50:36
 Re: 300 u ipto in reply to B Watson, 01-10-2005 06:43:41
yes if you hold down it slightly it stops but i dont think its on the levers --ive move all those adjustments
Redned
01-10-2005 15:43:06
 Re: 300 u ipto in reply to randy, 01-10-2005 06:50:36
I think the bands are availible from Case/IH? Big Bucks !
Paul H. Perry
01-14-2005 12:02:43
 Re: 300 u ipto in reply to Redned, 01-10-2005 15:43:06
When I was a kid Dad bought one new - PTO ALWAYS turned . . . unless, as B Watson posted, you held down the lever. I remember resting my foot on it . . . for no good reason I suppose, but it stopped the shaft from rotating.
