What have you guys been paying or charging?
Hal S.
12-07-2004 04:27:12
I know this is a little off the tractor subject. But, I was wandering what you guys have been charging and/or paying for custom baling for small square poly twine tied bales this past year? Not including the wagon labor, just the baling.
Andy Martin
12-07-2004 14:30:53
 Re: What have you guys been paying or charging? in reply to Hal S., 12-07-2004 04:27:12
I'm in Oklahoma and charge $1.10/bale to swath and bale with wire. Thinking about going to $1.25.
Wire runs about $0.10 per bale.
Mow only, $0.50, bale only $0.60.
caseyc
12-07-2004 06:02:37
i charge the same as kellyc, 1.00 per bale. if i need my wagons and have to haul them it's 1.50 per bale. i'm in eastcentral SD and bale with a 706 farmall and a 336JD baler.
casey
jal-SD
12-07-2004 06:30:40
 Re: What have you guys been paying or charging? in reply to caseyc, 12-07-2004 06:02:37
Caseyc, where in E central SD are you? I'm @ Mitchell. (My $0.02 worth. jal-SD)
caseyc
12-07-2004 06:35:15
 Re: What have you guys been paying or charging? in reply to jal-SD, 12-07-2004 06:30:40
i'm by toronto, halfway between brookings and watertown.
casey
Kelly C
12-07-2004 04:52:37
third party image
I charge $1 a bale dropped on the ground or you can work the racks.
Thats for cut, Raked and baled.
If shares its 50%.
I use sasle twine but would use what ever the customer wants if its an issue.
bent
12-07-2004 07:42:51
 Re: What have you guys been paying or charging? in reply to Kelly C, 12-07-2004 04:52:37
That's an awesome setup! I have a 214T, is that a 24T?
Brent
Kelly C
12-07-2004 19:46:51
 Re: What have you guys been paying or charging? in reply to bent, 12-07-2004 07:42:51
third party image
Thats my 14t. I got that one this summer.
Paid $150 on ebay for it. Greased her up and took it to the field. Perfect bales the 1st time.
Glenn F.
12-07-2004 07:41:20
Looks good. What size is your tractor? Glenn F.
Kelly C
12-07-2004 19:39:51
 Re: What have you guys been paying or charging? in reply to Glenn F., 12-07-2004 07:41:20
third party image
Thats my Farmall 400. Might be just about the best small baler tractor out there.
Live power and the TA. TA I have found to be great when you get into a heavy section of windrow. I usually bale in 2nd gear 3/4 throttle.
(depends on the baler)
When you hit a thicker section I dont even have to clutch, just pull the TA back and cuts the speed by 3rd and chugs through the thick spot. Then just push the TA forward and back at it.
