Starter terminal
daniel
08-25-2004 07:50:44
on my h starter the top postive terminal is really loose, it wiggles back and forth is there a way to fix it, it is the copper piece coming out of the starter. I think it is broken inside the starter.
Wayne Swenson
08-25-2004 15:49:13
 Re: Starter terminal in reply to daniel, 08-25-2004 07:50:44
There should be 2 hex nuts on the terminal post. One snugs the post to the insulating washers & case and the other attaches the battery cable. Remove the cable and inspection band; look inside (may need a mirror) and determine if you can tighten the nut securing the post to the starter case. Starter disassembly may be in order.
Be certain the insulator washer is in place so the battery cable isn't grounded to the case.
The Red
08-25-2004 09:12:19
If your starter is not spinning, that post more than likely is broken inside. Any good generator shop can replace that. I had one go bad on an H starter.
