Help with F-30
Jerry
07-22-2004 19:20:03
I have been looking for a set of sleeves and pistons for an F-30 (same as a 10-20). I've only been able to locate a couple sets, both of which are not for sale. I was wondering if someone had a set, or knew someone that had a set that they were willing to part with.
Also, I was thinking of boring it out a little and putting some pistons in it that are more available. I believe that a set of I-9 industrial pistons might work. (not that there a lot of them around either) They are the closest to the size I've found. An F-30 has a 4-1/4" in bore with a 5" stoke the I-9 has a 4.4" bore with a 5" stoke. I would be taking .150 out, which is only .075 off the wall. Would this lead to heat problems? How thick are the sleeves in an F-30? I heard they might be a half inch thick. Any ideas would be much appreciated.
Thanks, Jerry
pg
07-23-2004 03:17:18
 Re: Help with F-30 in reply to Jerry, 07-22-2004 19:20:03
rice equipment in penn has aftermarket sleeves and pistons, rings,ect,.....1-814-226-9200. if you want nos parts, give weber tractor works a call. both are on the net. pg
Jerry
07-24-2004 00:09:55
 Re: Re: Help with F-30 in reply to pg, 07-23-2004 03:17:18
I already tried them and they don't carry F-30 sleeves and pistons. They do carry about everything else for an F-30 though.
Thanks anyway, Jerry
