LP tractors
Jed
06-22-2004 07:04:43
I just got an 806 & a 706 that are LP tractors.
In regards to starting them could some one make me a basic starting instruction guide. You know turn this and pull that or whatever. I am totally ignorant when it comes to starting this sort of tractor.
doorguy
06-22-2004 20:35:33
 Re: LP tractors in reply to Jed , 06-22-2004 07:04:43
To start an LP engine, first open the valve marked "vapor" and start engine as you would any gas engine. After engine warms up, open "liquid" valve and close "vapor" valve. When engine is shut down, for more than a few minutes, be sure both valves are closed to prevent propane loss. Good luck, Lp tractors are nowhere near as hard to deal with as they first appear. doorguy
MD Wa.
06-22-2004 07:33:32
Jed. The only thing you need to do is turn on the valve at the LP tank and then start as you would a gas tractor. Mogan
