Removing Drive Dog on M lift-all pump
nick
06-16-2004 15:40:12
I have the pump out. The drive dog has to come off the pump drive shaft but the entire shaft just spins. It is threaded on to the shaft; right? How can I hold the shaft from spinning? Does the entire cover plate come off with the shaft, seal, & drive dog??
riverbend
06-16-2004 20:09:52
 Re: Removing Drive Dog on M lift-all pump in reply to nick, 06-16-2004 15:40:12
What a great time to buy a set of manuals. Apriori knowledge will only take you so far.
nick
06-18-2004 14:47:29
 Re: Re: Removing Drive Dog on M lift-all pump in reply to riverbend, 06-16-2004 20:09:52
I tried putting a bar up the filler and the drain plug with no luck. The shaft still spins because I can't feel any gears. Anyone take one apart.
John (AZ)
06-16-2004 15:51:59
If memory serves my correctly you have to place a steel bar into the pump intake inside the liftall housing to lock the gears to get the input coupler off the pump shaft.
john *.?-!.* cub owner
06-16-2004 15:54:31
 Re: Re: Removing Drive Dog on M lift-all pump in reply to John (AZ), 06-16-2004 15:51:59
According to the I&T manual, after removing the front from the assembly you are supposed to insert a steel bar up the oil intake to hold the gears so it can be unscrewed.
