Size of Offset Harrow for M
BB
06-12-2004 19:38:33
I am looking for a offset harrow for my 48 M and was wanting to know what size to look for. Didnt want to buy one to big and the M not pull it. Thanks.
BB
Jimmy King
06-14-2004 02:49:23
 Re: Size of Offset Harrow for M in reply to BB, 06-12-2004 19:38:33
I had a Roam 7ft. offset plow for years it was all a 400D or 460D needed. My uncle used once with his M pulled but wouldn't lift it.
Hugh MacKay
06-13-2004 17:33:55
Kind of curious what you guys are calling an offset harrow. I had what Bush Hog called a tandem offset disk, 10 foot with 26" blades. If I recall it had 14 blades on each gang. It would create all the load a 100 hp tractor wanted. I hitched 560 to it one day and I didn't go anywhere. Not enough traction to even touch it.
I do realize there were lighter versions of the same type of disk. But I think even the lightest I've seen, 10' would stump an M.
CNKS
06-13-2004 19:54:01
 Re: Re: Size of Offset Harrow for M in reply to Hugh MacKay, 06-13-2004 17:33:55
Hugh, that would be my opinion also. I would think a 10 foot "single offset" (two gangs) would be more than enough for an M. I have pulled one of these with a JD 3020 (about 70 hp) and it doesn't exactly walk away with it. This is a heavy duty disk that will go deep. The one you mentioned is called a double offset (four gangs) in this part or the country. It would be the same as pulling two single offsets hooked together, if that were possible. 100 hp minimum.
Hugh MacKay
06-14-2004 03:36:05
 Re: Re: Re: Size of Offset Harrow for M in reply to CNKS, 06-13-2004 19:54:01
CNKS: My description of my disk was not very good. From yours I can tell we are talking about the same disk. Single offset, pulls a bit off to one side, with front and rear gangs. The one I had would go 8 to 10 inches deep in corn stover in fall after combining. I usually pulled it with 100 hp or more. The time I hitched 560 to it, I didn't go anywhere.
49 Cubber!
06-13-2004 05:00:53
We had I think it was a International B-20 offset,10 or 12 ft wide.Ole M pulled it like there was no tomorrow.Probably could have gone a little bigger.The discx were only a year or two away from need replacing but it would sink to the spools and the M wouldnt even think twice about it.
gene b
06-13-2004 03:40:13
If you mean an of-set disc harrow 10ft is plenty in plowed ground if you are going over 3-4in deep.
