Front blade for Super C
Dave 2N
05-07-2004 05:49:45
Does anyone know the I-H model of the front blade setup they made for C's and Super C's?
crockofbc
05-07-2004 08:54:19
 Re: Front blade for Super C in reply to Dave 2N, 05-07-2004 05:49:45
The grader blade for C and Super C is model C-72
Dave 2N
05-07-2004 10:38:27
 Re: Re: Front blade for Super C in reply to crockofbc, 05-07-2004 08:54:19
Crock-
Thanks for the reply; does that model number cover the whole thing? Blade, frame, etc. Or is it just the blade?
thanks
crockofbc
05-08-2004 05:06:56
 Re: Re: Re: Front blade for Super C in reply to Dave 2N, 05-07-2004 10:38:27
Model C-72 Leveling and Grader Blade built 1953 to 1954
Model 2C-72 built 1954 to 1956 exactly the same as C-72 except model renamed when farmall 200 came out. Both models fit C, Super C and 200.
Model No. 72 built 1957 to 1963. Has some design changes from earlier models. For example the connecting rods (for C, Super C and 200) from the touch control unit arms have springs on them instead of the original solid arms. The rockshaft on the front of the tractor where the lifting straps attach is also different. Parts to attach the blade to 230, 240 and 404 were also available including an adapter to belly mount the blade on a 404 with 3 point hitch. The 230, 240 and 404 need a hydraulic cylinder. The frame and blade parts are the same for all models, just the lifting and mounting parts changed.
crockofbc
05-07-2004 12:04:57
That model number covers the whole unit, mounting frame linkages and the blade. When I get home tonight I can look at my parts manuals and give you a run down of the model number progression and which tractors it fits with the right adapting parts.
