F200 hydraulic pump rebuild
RT (seTX)
04-26-2004 10:03:17
The hyd pump on my Farmall 200 has 360687R91 stamped on the housing. The parts book says 360689R92 for the Pesco pump, 355362R91 for gasket set, and 360691R91 for gasket/shaft seal set.
Will the 689 parts fit the 687 pump?
Anyone bought a gasket/shaft seal set lately?
gauger
04-26-2004 19:09:31
 Re: F200 hydraulic pump rebuild in reply to RT (seTX), 04-26-2004 10:03:17
Get the kit from your Case dealer, I've done a number of these and the kits have extra o-rings and fiber rings. There is chart that show's the right parts to use for the different variation numbers. The instructions are detailed and easy to follow. The short answer to your question is yes. Pay close attention to the advice they give on making a seal "jumper" to avoid nicking the shaft seal o-ring upon reassembly.
