656 Diesel batteries
Glow Plug
04-19-2004 19:03:42
What causes the battery trays on my 656 diesel to turn green and corrode? Batteries are not over filled, -2- 6 volts& and the cables are good. Thanks, Glow Plug
MEK
04-20-2004 05:51:14
 Re: 656 Diesel batteries in reply to Glow Plug, 04-19-2004 19:03:42
The battery is filled with sulfuric acid, and it's not sealed. As the water in the battery evaporates, I would hazard to guess some of the acid goes with it.
Hugh MacKay
04-20-2004 02:47:56
The factory battery trays on a 656 were something I didn't tolerate very long. I think the batteries get much too hot in there. The other thing I ran into here in Canada was I wanted larger batteries I built two battery trays that mounted each side of torgue tube. If everyone had done this there wouldn't be so many of these tractors today with shift linkage, etc. corroded to bits. European built tractors mounted the batteries between seat and fenders, and in 15 years both were destroyed.
