I.H.3444
John G
04-04-2004 17:20:54
I have a I.H.3444,the oil level keeps rising when I run it.I changed the fuel pump from mechanical to electric and it`s still happening.Can it possibly be hydraulic fluid leaking into the engine?Does anybody know where to get a carb rebuild kit for a zenith VN serial#3228? J.G.
ken
04-05-2004 06:02:55
 Re: Re: I.H.3444 in reply to parts man, 04-04-2004 20:00:43
parts man i think thats the guy.
ken
04-04-2004 19:09:24
 Re: I.H.3444 in reply to John G, 04-04-2004 17:20:54
i know when mine gave me trouble i couldn't find a kit,or something was wore out in the throttle body don't remember it's been so long,anyway the ih dealer told me of a guy in ohio i believe that rebuilds them with a new bowl assy you send yours and he sends you back the rebuilt one but i think he wanted like 350.00 ,what i did was took a carb off an old cj2a willys jeep.bolted right up and works great the only problem is it stands taller and you either have to run without the hood or cut a notch in it for the aircleaner hose.as for it getting full of oil.i'd check the hyd fluid to see if it's dropping otherwise it would have to be water.
