350D DIESEL
Joe
03-24-2004 12:49:44
Hello, I cant seem to find a air filter for my
350D diesel, anybody know where to get one or can i convert it to a ford or different filter.
Thanks alot
Evan350
03-24-2004 13:17:05
 Re: 350D DIESEL in reply to Joe, 03-24-2004 12:49:44
The 350D has an oil bath air cleaner. Unless it got bashed up so air doesn't flow through it any longer, all you have to do is take the bowl off the bottom, drain the oil out, clean it up, fill with clean motor oil to the line, and replace the bowl.
joe
03-24-2004 17:32:55
 Re: Re: 350D DIESEL in reply to Evan350, 03-24-2004 13:17:05
so there is no packing or anything that goes in the filter area, i see wherer the oil goes but what about above that
Hugh MacKay
03-25-2004 02:16:35
 Re: Re: Re: 350D DIESEL in reply to joe, 03-24-2004 17:32:55
Joe: If that steel wool looking material, that Ron speaks of, actually a very coarse looking steel wool is missing, it is a very necessary part of the filter system. That material is subject to rusting in tractors that have been parked a long time. I saw one of these rusted at a shop once, they didn't even try to replace the material, just shoped around and found a complete filter canister. Guy at the shop said in his opinion it was 90% sealed off by rust. If someone has removed that material from your filter, your easiest option is find another complete filter assembly. You can buy replacment dry type air filters, but again you will be buying complete assembly and you will have to be sure it has the proper capacity.
Ron in Nebr.
03-24-2004 20:34:42
There should be some steel wool-looking material in the cannister above the oil. It's not anything that ever usually gets replaced as a part of routine maintenance(or otherwise that I'm aware of). Just new oil once in awhile.
Scott
03-24-2004 18:36:04
The air is drawn thru the oil so the dirt is trapped in the oil. As long as you keep the oil at the line no other filter is needed as dirt cannot get thru oil.
