Throw Out Bearing-1949 Super AV
Tom
03-20-2004 14:41:51
I just installed a 9" rebuilt clutch kit and the throw out bearing that came with the kit was a standard automotive type bearing which does not fit on the spline shaft. The original bearing is a type of black bake lite (not is very good condition) that is inserted into a casting with two grease fittings. What do I do here guys??
Thank you
Tom
Haas
03-21-2004 06:46:03
 Re: Throw Out Bearing-1949 Super AV in reply to Tom, 03-20-2004 14:41:51
You can reuse the original bearing. If you use the new ball bearing that came with your kit, you will also need a new clutch release bearing holder to install it. The new bearing holder will replace the casting that holds the old style bearing.
