Farmal FBH ?
steve hales
03-08-2004 18:08:26
I am looking to buy this Farmall Tractor and the serial number as far as I can see is;
serial # FBH 139482
engine# FBH 139482 I can read the engine # a lot better and that is real easy to read.However it could be FB11? I can't find that model in the serial number pages. I am trying to make an reasonable offer to a fellow.any help I can get would be most appreciated.
steve
Digger
03-08-2004 19:07:11
 Re: Farmal FBH ? in reply to steve hales, 03-08-2004 18:08:26
If you also look above the distibutor there is a flat spot on your engine block that will need to be cleaned it will also have your seriel# stamped on it to,with the FBH so you know that your motor matches your tractor.
sammy the RED
03-08-2004 18:43:45
FBH is on all the H's.
Dave_Id
03-08-2004 18:14:46
Farmall H
steve hales
03-08-2004 22:37:55
 Re: Re: Farmal FBH ? in reply to Dave_Id, 03-08-2004 18:14:46
Thanks guys for all your help. I will be back with more interesting questions. This is a great group
steve
