SA hydraulic pump question
mikeinWA
03-05-2004 21:39:03
Just replaced seals on hyd. pump and it feels a little tight when I turn the drive gear. Wasnt smart enough to test it before dissasembly for a comparison. Is there some rule of thumb out there?
CNKS
03-06-2004 13:51:25
 Re: SA hydraulic pump question in reply to mikeinWA, 03-05-2004 21:39:03
If you are sure the tightness is caused by the seal, don't worry about it. As long as you used the right size seal you are ok. I believe the ones I have done seemed tight also -- has to be tight to prevent leakage.
