f20 valve cover has extra hole
JDKINNEBR
03-05-2004 10:51:06
I have two F20 valve covers and they both appear to have two extra holes, was that for an oiler or something?
Walt in Jaxn Tn.
03-05-2004 11:33:04
 Re: f20 valve cover has extra hole in reply to JDKINNEBR, 03-05-2004 10:51:06
There is a total of six holes in the valve cover. Two are for the bolts that hold the cover on, two are gitz oilers with little spring loaded caps to oil the troughs that keep the rocker arm and valve assembly oiled and the remaining two are for primers that go down thru the head to the intake passeges to dump raw gas to help in starting a cold dry engine. Are you putting a F-20 together?
