H, SH, M, SM, SMTA drawbar braces.
Dave H (MI)
01-19-2004 07:44:14
I have to replace the drawbar brace on my MTA before hay season starts (11 replies to classified ad I placed, thank you!)and want to make sure I get the right one. It is the diagonal brace found on either side of horseshoe shaped fixed drawbar, has a round shaft with holes for bolting on at each end. OEM lists one part for the above referenced tractors. Many have offered used alternatives from the same models. Can any of you guys with multiple tractors tell me if they have the same size (length, thickness, etc)braces on the drawbar? I guess I could just take OEM's word for it, but the woman on the phone was not overly helpful so I thought I would put it to the forum.
jim in ny
01-19-2004 09:31:58
 Re: H, SH, M, SM, SMTA drawbar braces. in reply to Dave H (MI), 01-19-2004 07:44:14
they made I think 3 different lengths, i think thickness was the same. new ones are not availible. you can use different lengths on same tractor by using a different hole in horseshoe to compensate for different lengths of braces.that way you dont have to be so fussy at the junkyard.
Hugh MacKay
01-19-2004 08:42:33
Dave: I know the braces for 300 and 560 are exactly the same. I bought new ones for both from IH in the mid 60's. They all came at same time.
