IH 2000 loader
Don
01-02-2004 13:41:39
I have a IH 350 Utility and Iam looking for a loader, I see one on Ebay that is a IH model 2000, the starting price is $500.00. First will this fit my 350 and is this price OK?
Keith T
01-03-2004 10:51:39
 Re: IH 2000 loader in reply to Don, 01-02-2004 13:41:39
Just checked Ebay ,would say it is a 2001 as 2000's had hydraulic dump on the buckets .You may be lucky ,he says its off of a utility
Hugh MacKay
01-02-2004 20:01:54
Don: I had a 2000 loader on my 560 Farmall. I sold the loader without the tractor and the buyer installed it on a 300 Farmall. He just had to cut 6" out of loader frame back where it bolts to rear axle. Of course 6" is the exact difference in wheel base between 4 cylinder and 6 cylinder Farmalls of that era. I have seen 2000 loaders on 460U and 504U, they use a slightly different mounting kit from Farmalls. You will likely have to modify and fabricate your own mounting hardware. The 2000 is a good strong loader, I would say price not bad.
Keith T
01-03-2004 10:37:03
 Re: Re: IH 2000 loader in reply to Hugh MacKay, 01-02-2004 20:01:54
2000 loaders were made for just about all but the smallest IH tractors.The hitch was that there were about 20 different sub-frames to make it fit all the various models not to mention Farmall and utility mod. of the same # The lift and dump parts were all the same .It probably will require some blacksmithing unless you are lucky and get the right sub-frame
