656 v.s. 4 bottom plow
John
12-28-2003 11:57:57
What is a Farmall 656 gear drive rated to pull for a plow. i had a 3-14" that i used until i broke the axle, i just bought a 4-14" to replace it.. should it handle the 4 bottom or should i take a bottom off?? i see most 560's pulling 4 bottoms and a 656 is the upgrade of the 560.. any info would be appreciated..
Runner,Al.
12-28-2003 16:48:24
 Re: 656 v.s. 4 bottom plow in reply to John, 12-28-2003 11:57:57
Soil Types- make all the differance. I pull 4-16's with and 806-diesel. I pull it about 10inch's deep. It is a load!
steve450
12-28-2003 14:38:02
I pull a 4x16 oliver semi-mount with my 656D in 2nd gear no problem. Only have to pull the TA once in a while going up hill. I even plowed some OLD sod this fall and she did just fine.
sammy the RED
12-28-2003 13:33:42
A 656 has a smaller motor and a little less horse power than a 560.
Hugh MacKay
12-28-2003 13:59:40
 Re: Re: 656 v.s. 4 bottom plow in reply to sammy the RED, 12-28-2003 13:33:42
sammy: In diesel they are exactly the same 282 cubic inch, 540 pto at 1800 rpm. I pulled a NO. 60 - 4x16 plow for several years with 560. Later I went to a semi mount plow Model NO. 510 - 5x16. I pulled that with 656 clearly because of 3 point hitch. I put well over 10,000 hours on each of these tractors. The 560 does have an edge on drawbar pull as it is heavier.
I might also add the diesel pump was turned up on my 560 for more power on field cultivator and forage harvester. However from factory they are very close.
42FarmallH
12-28-2003 13:51:03
The 656 has the SAME diesel engine as a 560 - the d282 with glow plugs.
As for gas engines, I don't know - but I don't see why IH would put a smaller engine with less hp in a bigger tractor...
john d
12-28-2003 13:13:31
Soil types make a huge difference, but we pulled a 4-14" trailing Moline plow for years with a Farmall Super M in 2nd and 3rd gears.
Gary
12-29-2003 18:27:51
 Re: Re: 656 v.s. 4 bottom plow in reply to john d, 12-28-2003 13:13:31
We sold a lot of 656 tractors where I work. Most pulled 4 sixteen inch plows. Had no complaints about power. The 656 has the same size engine as the 560. A 282 Diesel or a 263 gas engine
