IH/Farmall I-404 - Other Names?
Stretch_03
12-26-2003 10:16:39
Merry Christmas everyone.
I have a 1963 IH Farmall I-404 (with C-135 engine). I hear alot about "C" and "H" tractors. I browse the message posts looking for something related to my tractor, but I never see an "I" post. Is there another name for the I-404? I mean, is it a member of a "C" class, or something like that?
Thanks... Larry
Richard
12-26-2003 19:06:43
 Re: IH/Farmall I-404 - Other Names? in reply to Stretch_03, 12-26-2003 10:16:39
My neighbor has the International utility 404. Even though I use Deere equipment on my side of the fence, I admire that little tractor. He uses it extensively, mowing, post hole digging, moving bales and such. It sits outside and waits for its calling. I borrowed it once to pull a rake. That sure is a good little machine.
CNKS
12-26-2003 18:27:50
If your tractor has a wide front and 28 inch rear wheels it is an International 404. If it has 36 inch (possibly 38, but I don't think so) rear wheels and either a wide front or a tricycle or narrow front it is a Farmall 404. These tractors are loosely related to the C/Super C/200,230,240 series in that the engine is similar, as is the 4 speed transmission. The engine is a member of the C-113/123/135 series.
Stretch_03
12-28-2003 21:41:11
 Re: Re: IH/Farmall I-404 - Other Names? in reply to CNKS, 12-26-2003 18:27:50
third party image
First, thanks for all your comments.
I'm pretty sure it's an "I-404"... at least, that's what the ID tag says. It was made for the military (again, according to the serial/ID tag). It's a wide-front with 28" rear wheels. I'm not sure about the tranny, I only know it has 4 speeds and unknown whether there are more or not. It definitely has the C-135 engine (I'm tearing it down right now...and it's a mess).
Some unusual things about it... 1) it's yellow (I can;t find yellow paint in any of the Farmall/IH schemes); 2) it has a super-heavy-duty dash throttle (very heavy cast metal with no wobble like most dash throttle levers); 3) it has a gas pedal too on the right side.
CNKS
12-26-2003 19:01:15
Actually, the 404 transmission is a 2-range 4 speed, giving 8 forward and 2 reverse. Live PTO was available on the later models.
Hugh MacKay
12-27-2003 18:32:29
 Re: Re: Re: IH/Farmall I-404 - Other Names? in reply to CNKS, 12-26-2003 19:01:15
CNKS: I have an IT service manual and just want to remind you of the 2404. This manual also calls the high-low range an option. A forward-reverse was also an option. Those two were both options and were either or, not both. It also makes no mention of Live PTO. I don't see a printing date but the manual is called No. IH-21
Harold H
12-26-2003 18:05:41
If your 404 is a I-404 it is a International 404. If it is a row crop type tractor it is a F-404 which is a Farmall 404. Generally speaking Farmall tractors are row crop whereas International tractors are standard or utility (in the case of the 404) type.
Harold H
Bob
12-26-2003 10:21:04
"C" and "H" WERE the model numbers of those older tractors. Your "I" 404 is an "International", as opposed to a McCormick, and "404" is it's model number.
There is a long story behind which International Harvester tractors were badged "McCormick", and which were badged "International", and I'm sure someone will post that.
Bob
12-26-2003 10:23:06
 Re: Re: IH/Farmall I-404 - Other Names? in reply to Bob, 12-26-2003 10:21:04
P.S....
I have one of your 404's bigger brothers, a 424 diesel. It's been a heck of a good little tractor.
Van
12-26-2003 11:30:35
 Re: Re: Re: IH/Farmall I-404 - Other Names? in reply to Bob, 12-26-2003 10:23:06
Don't know about bigger, just newer.
