300 row crop power steering
Jim
11-14-2003 12:30:05
I have a 1955 300 rowcrop. Although the powersteering unit looks factory installed and works fine, its plumbed into the drain plug of the hydraulic resevoir, which I suspect isnt correct. Where would the hydraulic hose have originally been connected? Can i just put in a tee somewhere?If so, where? The IT manual doesnt show any diagrams.
26Red
11-14-2003 13:34:49
 Re: 300 row crop power steering in reply to Jim , 11-14-2003 12:30:05
My 300 is the same way. It is plumbed the correctly because that's what shows the routing in the parts book.
Jim
11-14-2003 14:23:29
 Re: Re: 300 row crop power steering in reply to 26Red, 11-14-2003 13:34:49
Thanks...gee, youd have thought they wouldve come up with a cleaner install than that....but hey, it works :)
Aces
11-14-2003 12:37:24
If it came from the factory with Power steering it would not be in the drain hole, don't remember where but under the hood some place.
Red Rider
11-14-2003 19:29:26
 Re: Re: 300 row crop power steering in reply to Aces, 11-14-2003 12:37:24
Sorry aces, but you are wrong. The IH parts book shows the return line from the power steering motor does return in the drain plug. I have change the return location on my Farmall 300. On the same side of the hydraulic reservoir as the drain plug there two raised spots about 1" square. I just drilled and tapped 1/2" pipe for my return.
