Order Farmall Cub Parts Online
Cub, won't run like a Deere
cityboy
10-19-2003 15:32:47
First of all, great web site, it's on my fav list!
I bought a 1976 Cub this fall and it needs some help, starts and runs good but under a load with the belly mover it bogs and pings bad. I have changed the plugs and blades on the deck, any ideas what will give it a little more power?
Big Ox Titan
10-20-2003 08:48:41
 Re: Cub, won't run like a Deere in reply to cityboy, 10-19-2003 15:32:47
Nothing runs away from the cub faster than the Deere.
Jon Blanc
10-20-2003 04:29:08
Ah... but your Cub does run like a Deere! What you want is for it to run like a Farmall. Jon
Slappy
10-20-2003 06:16:08
 Re: Re: Cub, won't run like a Deere in reply to Jon Blanc, 10-20-2003 04:29:08
Jon, you made my day!
rustyfarmall
10-20-2003 07:24:43
 Re: Re: Re: Cub, won't run like a Deere in reply to Slappy, 10-20-2003 06:16:08
Only time I saw a Deere run was when it was running away from the work.
Nebraska Cowman
10-20-2003 03:25:48
fav list? it's my home page. check your timing, just rotae the distributer a little with the motor running, i bet it clears right up.
Bigdog
10-19-2003 17:29:12
I would suggest an owner's manual. You will find it invaluable in maintaining your tractor. It answers a lot of questions. But for starters, check your timing. Sounds like it could be off.
jakee
10-20-2003 18:28:13
 Re: Re: Cub, won't run like a Deere in reply to Bigdog, 10-19-2003 17:29:12
don,t just turn the distribitor mark all the timing marck,s and use a timing light at idel, then bring it up to full rpm,s and see if the distribitor is advancing to the proper deegrese.
