What engines will fit a TD-6?
Rustidiot
10-16-2003 19:49:20
I have a TD-6 with a bad engine. I have heard that other International gas-start diesels will fit. Also, will a Farmall M straight gas engine fit? Thanks in advance.
Geoff
10-18-2003 20:39:04
 Re: What engines will fit a TD-6? in reply to Rustidiot, 10-16-2003 19:49:20
The M gas ( C-248 ) is about an inch and a half shorter than an MD ( D 248 ) but the Super MD and 400 D and 450 D would all bolt in
Hugh MacKay
10-17-2003 02:23:31
The following engines will fit UD6, WD6, MD, SMD, 400, W400, 450 and W450. I know of one W400 that had the diesel changed to gas with few minor problems, so I would assume the exchange diesel for gas can be done with all of them.
MD Wa.
10-16-2003 21:56:13
Rustidot. The engine out of a MD should (will) bolt in. That is the only one. WD4 ID4 TD4 = HD WD6 ID6 TD6 = MD WD9 ID9 TD9
The gas models are the same match. The parts book shows the same front frame for both W9 and WD9 so maybe the gas and diesel engines are interchangable. Morgan
Mike
10-17-2003 14:25:35
 Re: Re: What engines will fit a TD-6? in reply to MD Wa., 10-16-2003 21:56:13
What is a (HD) never herd of one?
Wilhelm
10-17-2003 12:43:42
HD? I think you should get your facts straight.
Farmaller
10-17-2003 19:16:58
 Re: Re: Re: What engines will fit a TD-6? in reply to Wilhelm, 10-17-2003 12:43:42
If anyone has a WD-4 I would like to be the first one to buy it.
