Float setting for Farmall F-20 Zenith carb
GP
09-08-2003 09:46:52
How should the float be set for an F-20 with the Zenith K5 carb? Thanks!
KBBob
09-08-2003 13:01:41
 Re: Float setting for Farmall F-20 Zenith carb in reply to GP, 09-08-2003 09:46:52
with the fuel valve and float installed, invert the upper body and measure from the gasket surface to what is now the top of the float. Should measure 1 and 49/64 inches. Hope this helps, good luck.
