656 3 point hitch
BOB
07-13-2003 13:03:30
I have got this 656 and the 3 point hitch was working fine and then the next time i went to raise it it would not come up i have taking the rockshaft housing all apart and checked it over found nothing wroung other than the cushion valve had a broken spring any ony have any ideas.
tyner
12-25-2004 09:44:09
 Re: 656 3 point hitch in reply to BOB , 07-13-2003 13:03:30
My father has a 656 that has a draw bar on the back and would like to put a 3 pt on it. Does anyone have any pics or advice on what to do or the cost. It has two levers and hydro links under the left side of the seat.
wolfy
07-13-2003 17:28:33
First thing to try is: With hitch lever in raised position, lift the remote valve lever. If hitch raises this way, you're good to go til the next rainy day when you have time to take top off(under seat) & re-attach seal that slips off.
Aces
07-13-2003 17:16:08
If the cushion relief spring was broken and the valve did not seat that could be your only problem. The oil would just pump into the cylinder and out the valve back to the resivor.
Rich
07-13-2003 13:36:17
How about the hud.pump or the relief valve or hyd filter or draft setting. Should start there
