1940 M Farmall
Van
07-12-2003 07:59:47
I found a M farmall for sale that codes out to be a 1940 model, the serial number is 5 numbers and has a fbk prefix, what puzzles me is that it has a X 1 following the number. It also has a live hydrualic pump and a vertical distrubutor in the normal location to allow it to clear the oil filter. Can anyone identify this machine and tell me about the strange distributor adapter and what the X 1 means? thanks
rustyfarmall
07-12-2003 09:38:57
 Re: 1940 M Farmall in reply to Van, 07-12-2003 07:59:47
X-1 means your tractor came from the factory equipped to burn gasoline. If the tractor has a live pump, it has been added on, would not have been standard equipment, or even available as an option. The distributor is a Delco-Remy, very common. Tractor would have originally been equipped with a magneto ignition system, but most of them were converted to a distributor.
Van
07-12-2003 12:15:42
 Re: Re: 1940 M Farmall in reply to rustyfarmall, 07-12-2003 09:38:57
Thanks for the info, most of the old machines around here were distillate rigs. I thought the live power was a retrofit, I have a similar but hard line version on my 300's. but the vertical distributor had me scratching my head. Is there someplace to find the Serial # "other" codes in case i run up against this again.
CNKS
07-12-2003 18:42:02
 Re: Re: Re: 1940 M Farmall in reply to Van, 07-12-2003 12:15:42
Get Guy Fay's "International Harvester Tractor Data Book", has all the codes in it. Your local book store or Amazon, Barnes and Noble, etc.
Van
07-12-2003 12:17:57
Also noticed that the Dist does look identical onthe outside to other IH distibutors
rustyfarmall
07-12-2003 13:07:58
 Re: Re: Re: Re: 1940 M Farmall in reply to Van, 07-12-2003 12:17:57
Although the delco looks similar on the outside, when you go the store for new points, condensor, etc., you will need to tell the parts man that you have a delco dist., the internal parts will not interchange with the I.H. distributors, nor will the dist. cap.
Van
07-16-2003 21:51:46
 Re: Re: Re: Re: Re: 1940 M Farmall in reply to rustyfarmall, 07-12-2003 13:07:58
Thanks for the info
