10/20 carb.
stanley j.
07-09-2003 16:41:12
on a carb on a 10/20, what is the correct setting on the jets, also which one is the idle and load on the carb, one ajustment is on the top of the carb. and the other on the bottom, also need to know what settings to start out with, thanks for your help. stanley
Ken Williams
07-10-2003 09:15:26
 Re: 10/20 carb. in reply to stanley j., 07-09-2003 16:41:12
Stanley, the fuel adjusting screw is on top of the fuel bowl. Open this up 1 and 1/2 turns. The idle adjustment screw is underneath the carburetor. Open this up 2 and 1/2 turns. After the engine is warmed up, screw in the fuel adjusting screw (in the center of the fuel bowl cover) one notch at a time, until the engine begins to slow down. Then, back this screw back out carefully, until the engine regains full speed, then stop. I hope this helps, Ken
