706 gas Farmall cranks, but won't start
Chad
05-11-2003 14:30:08
I have a 706 gas Farmall that ran fine at the end of last season. It would start right up with the push of the button. It sat over the winter outside without being started, and now it will crank, but won't even try to fire. I changed the plugs, wires, points and condenser last year, and it ran great. I pulled the plugs when it wouldn't start the other day, and they were all fouled out, so I sanded and wiped them off, but no luck yet. Any help would be greatly appreciated! Thanks!
Gary in TX
05-11-2003 20:33:18
 Re: 706 gas Farmall cranks, but won't start in reply to Chad , 05-11-2003 14:30:08
I have always heard there is only 3 things that can keep an engine from running, fuel, fire adn compression. My bet is if you clean up that dist. cap and check ignition you may just find your problem. You say there is gas in teh carb. , question is it getting to the plugs????
Could be a gummed up carb too.
Chad
05-11-2003 21:12:33
 Re: Re: 706 gas Farmall cranks, but won't start in reply to Gary in TX, 05-11-2003 20:33:18
I tried holding the plug wire a 1/2 inch away from the plug and got spark. I think there may be a problem getting fuel to the cylinders though. We bought it last year and have been trying to bring it up to specs as far as maintainence goes. The gas tank is rusted inside and needs cleaned out. We will take that off in the next couple of days and get it to a radiator shop. Once we do that, I suppose we can check the lines to make sure there aren't any clogs... My father pulled the carb. apart recently, after it wouldn't start so I am not sure if there could be a problem there. I know it needs a new gasket kit, which we have to put on. I've heard there isn't much to go wrong on these old things, so I'm sure with your suggestions, we'll locate the problem. Thanks for your help!
Mr. T
02-23-2005 07:13:48
 Re: Re: Re: 706 gas Farmall cranks, but won't star in reply to Chad , 05-11-2003 21:12:33
Doesn't it have a glass fuel sediment bowl? Rusty gas tank means stopped up strainer screen or even a large piece of rust can settle over the outlet.
Duh!!!!!!!!
05-11-2003 15:05:32
Did you turn the gas on????? ????? ?????
Chad
05-11-2003 15:08:16
 Re: Re: 706 gas Farmall cranks, but won't start in reply to Duh!!!!!!!!, 05-11-2003 15:05:32
Yes. Good suggestion though. When you crank it a while, there is gas in the carb., so I think it may not be getting fire.
Geoff
05-11-2003 15:29:44
 Re: Re: Re: 706 gas Farmall cranks, but won't start in reply to Chad , 05-11-2003 15:08:16
Try holding a plug wire about 1/2 inch away from the tip of a plug and see if you have spark. Things tend to get wet from condensation over the winter. The inside of the distibuter may be damp and shorting out. Good luck Geoff
Chad
05-11-2003 15:32:15
 Re: Re: Re: Re: 706 gas Farmall cranks, but won't start in reply to Geoff, 05-11-2003 15:29:44
Thanks, I'll try that, and let you know. I am fairly new to the tractor seen, so any help is always appreciated!
jodee
08-20-2003 20:16:37
 Re: Re: Re: Re: Re: 706 gas Farmall cranks, but wo in reply to Chad, 05-11-2003 15:32:15
you know i am having the same problem.. i just replaced the plugs,wires, coil, cilonoid, and the points, all the thing does is turn over and wont fire you could sit there all day and nothing happens (except of course it floods out) but if you know or anyone knows for that matter what they think the deal is let me know too...
