'36 F12 paint
bald
05-25-2002 20:34:26
Does anyone have any info on where to get the proper paint for this tractor. Note: the body & castings are presently painted dark gray & the wheels are dark red.
The Red Baron
05-27-2002 07:02:23
 Re: '36 F12 paint in reply to bald, 05-25-2002 20:34:26
While my 36 was red when I got it, it gradually became apparent (after I began to paint it red again) that it had been originally gray. I mistake that has always bothered me. The serial number is 72160 if that helps you at all. If your tractor is in fact gray, I just want to point out that your wheels in fact would still properly be red if you want to be accurate.
Dan in Ore
05-26-2002 05:36:36
You might check the serial # to be sure of the year. All of the 36 model F-12's that I have seen are red.
I am restoring a 36 F-12 right now. Was hoping to have it for the local show this weekend, but didn't happen.
Good luck.
Dan
howard
05-27-2002 04:28:56
 Re: Re: '36 F12 paint in reply to Dan in Ore, 05-26-2002 05:36:36
paint was changed in november of 36 so you tractor was likly gray. I mix a gallon of rustoleum gloss black with about 2\3 cup of white.
