M oil pressure
Carden
06-19-2007 04:23:44
Does someone know what the average correct oil pressure should be for an M that has had the motor done to 4" specs and has only 30 hours on the rebuild? My gauge is pegged at 70 at idle and doesn't fully come back to zero when shut down and cooled off.
Andy Motteberg
06-19-2007 22:01:47
 Re: M oil pressure in reply to Carden, 06-19-2007 04:23:44
It depends if you are using an IH (Rochester) or a new repro gauge. If you have an IH gauge, the needle should point near the middle of the white area in the gauge. If you are using a repro, the needle should point in a green area or point around 55-60.
El Toro
06-19-2007 06:25:47
You need a calibrated gauge to be sure what the pressure is. Hal
CNKS
06-19-2007 05:34:16
Pressure should drop as rpm is decreased. Should be 60-70 at full throttle. You might try a new gauge -- be sure to get the one with the same number as is listed in the parts book as they have different pressure ranges.
Allan In NE
06-19-2007 05:25:38
Yep,
That be right.
Allan
