Vertical delco remy Distributor
Neal Butler
05-05-2007 20:55:40
I have a super H with a vertical delco distributor and the gear on the bottom of it is worn to the point that it will no longer turn the shaft to the distributor. I have looked for the replace part and am not having any luck. Can someone tell me where to look for this gear. It has 16 splines on it and the are at a slant, almost like a spider gear.
RustyFarmall
05-06-2007 05:00:27
 Re: Vertical delco remy Distributor in reply to Neal Butler, 05-05-2007 20:55:40
The vertical Delco distributor is quite common on Allis-Chalmers and also I believe Case tractors. Might open up a few more possibilities for you.
georgeky
05-05-2007 22:11:28
A neighbor had the same trouble on his H, and could not find the gear locally. Soooo he came to me and got an IH distibutor and drive housing and just swithced his to the IH distributor. It has worked good since.
