Torque specs for Farmall H rear wheel lugs?
Neil Fuller 2
05-04-2007 19:21:56
What are the torque specs for the lugs that clamp the hub to the rim?
Hugh MacKay
05-05-2007 03:00:58
 Re: Torque specs for Farmall H rear wheel lugs? in reply to Neil Fuller 2, 05-04-2007 19:21:56
Neil: I'd go with Gordon's cheater bar, then follow riverbend's advice on checking after you've used the tractor for awhile. The double check is important, both at axles and between hub and rim.
GordoSD
05-04-2007 20:19:43
I'd use a 3/4 bar with a 2 foot cheater and LEAN on it. Use a 3 foot cheater for the axle bolts. I also buy new bolts, washers and nuts for this. Put them on after paint.
Gordo
riverbend
05-04-2007 20:16:55
1)Tighten them as much as you can using a box end wrench without a cheater bar. 2)Use the tractor for a while and repeat step #1. 3) Repeat step #2 several times.
My manual does not show a specific torque value. Make sure you are using grade 5 or 8 bolts that are not too long.
Greg
