1954 Super H Hydraulics
Bigstone
04-16-2007 10:25:46
It seems that I have some a problem with my hydraulics. I raised the bucket to drive my tractor off of a trailer and now the loader will not go down. In fact it will not go up or down. the lever moves freely. I hope this is not serious. Any idea what could have happened and how I would go about fixing it? I woudl appreciate your help.
Bigstone
chadd
04-16-2007 12:42:34
 Re: 1954 Super H Hydraulics in reply to Bigstone, 04-16-2007 10:25:46
When you pull the lever, do you notice any load on the engine? If not, I would say your lever broke off or the shaft sheared or twisted off inside. If you notice a load, either you have couplers on it that don't match or are plugged/defective, or some valve in the system is stuck.
RustyFarmall
04-16-2007 11:13:58
Did a hose become disconnected? I'm not making fun, I've seen it happen.
bigstone
04-16-2007 18:54:20
 Re: 1954 Super H Hydraulics in reply to RustyFarmall, 04-16-2007 11:13:58
Hoses are all in tack .
Bob M
04-16-2007 10:40:24
Do you have the Liftall control lever (on the right side of the hyd reservoir) pulled all the way back and latched?
Bigstone
04-16-2007 18:57:44
 Re: 1954 Super H Hydraulics in reply to Bob M, 04-16-2007 10:40:24
Hi Bob,
I'm not sure what you mean, but I do have the lever pulled all the way back and over that little bump in the rod.
the tractor vet
04-16-2007 10:35:59
It maybe that the screw - bolt may have come loose and the linkage is just slipen or ya may have to go inside the unit and do sopme repairs . Hard to say with out being there. If ya have pioneer couplers ya may have one or two of them go bad ya may also be air locked as the breather may have gotten pluged.
