H Oil Pump
Tom Windsor
03-30-2007 16:47:27
When I broke down the oil pump that came off this engine, I found a full tooth broken off the idler gear and 1/2 tooth broken off the drive gear. Having rejected that unit, I went through 2 more units until I got myself satisfied that the bearings were not worn out, turned freely and had all its teeth.
Having said that, I have thoroughly cleaned this unit up and ready to put it back together. MY QUESTION IS:
Is there anything inparticular that I should be paying attention to when I assemble this unit. I don't want to be taking this pan off again if there is something I can do ahead of time.
TW
El Toro
03-30-2007 18:40:39
 Re: H Oil Pump in reply to Tom Windsor, 03-30-2007 16:47:27
When you have that oil pump reassembled you need to set it in a container of new engine oil and prime the pump. Spin the drive gear until oil is being discharged and then install it on the engine. Hal
Dave S.
03-30-2007 17:47:26
The bottom plate on my H pump was slightly worn from the gears, I took it to a machine shop and had it surfaced.
