McCormick Deering Hammer Mill No. 10 C
LinemanFarmer
03-25-2007 06:42:06
I ran across an up coming auction and found a McCormick Deering Hammer Mill No. 10 C. It looks like everything is there (the pipeing and the grates). You can see that it has been sheded all of its life, and paint isn't excellent but its still there. The drag chain is kinda froze up but with some oil I bet it would move. Every thing else moved and dosn't look very wore. Now Im a younger guy that has never seen one of these, what exactly can you mill threw this, and how much is one of these worth? Thanks Derek
gene bender
03-25-2007 10:41:22
 Re: McCormick Deering Hammer Mill No. 10 C in reply to LinemanFarmer, 03-25-2007 06:42:06
Never know who else wants it. I was bidding on one that was in super condition forgot about the bid time and lost it for 305. Friend know i was bidding and thought i won asked if i would take a 1000 as he had a friend that wants one bad.
Nebraska Cowman
03-25-2007 06:58:34
The mill is only limited by the size of screen. If you have a small enough screen you can grind wheat but shelled or ear corn were the most common uses. Did you know the use hammermills to prepare junk cars for the smelter? Each hammer is about the size of a grown man.
IaGary
03-25-2007 07:18:54
 Re: McCormick Deering Hammer Mill No. 10 C in reply to Nebraska Cowman, 03-25-2007 06:58:34
Cowman
They have a grinder like that at the steel mill my brother works at to grind cars.
Every once in a while it will get gummed up with tin.
So the have a pile of engine blocks there to throw in to clean the tin up.
It all comes out in 6 to 12 inch pieces.
I bet you wear ear plugs around it.
Gary
